Home Forums Products Rackmount Stereo preset image Reply To: Stereo preset image
#120844
    Need more information:
    1) Exactly what routing are you using ?
    2) If the presets you mention are in DSP A, what is in DSP B ?
    3) Does this happen with all presets ? If not, give the numbers of some that are OK.
    4) Does this happen with the THRU preset ?
    5) Have you tried swapping amps/cables ?
    6) Presumably your bass is mono. Is your preamp mono out or stereo out ?
