Reply To: 2 amps and eventide 4000 dsp
Home Forums Products Rackmount 2 amps and eventide 4000 dsp Reply To: 2 amps and eventide 4000 dsp
#120859
You should use mono cables. If your DSP4000has 1/4" jack outputs, use these, otherwise you will need XLR to mono jack cables, with pin 2 of the XLR connected to the tip of the jack, and pins 1,3 connected to the sleeve.
