Home Forums Products Rackmount Eclipse power-up V4.01 Reply To: Eclipse power-up V4.01
#120867
    You are correct – it should not do this. Sorry for the trouble.
    It is almost certainly caused by a problem with the internal battery. If you are technical, you could open the unit (power off) and make sure that the battery is properly installed and has nothing caught between its contacts.
    Or if otherwise, or if you understandably think that you should not have to do this, contact your dealer or support@eventide.com.
