Home › Forums › Products › Rackmount › PROBLEMS WITH LOOPS › Reply To: PROBLEMS WITH LOOPS
October 21, 2010 at 4:04 pm
#120881
Hard to know what one is listening to here. If you turn up the output gain on a digital system high enough, you can hear any number of bad things – one needs to know how it relates to a normal signal level.
You should check your AC power supply (this may be the source of the clicks), and also state whether it happens on all inputs and outputs (including digital).
