Home Forums Products Rackmount Having trouble with updatingto 5.5 using the Flash Card on H8000FW Reply To: Having trouble with updatingto 5.5 using the Flash Card on H8000FW
#120953
    When the H8000 is running normally you don't always get a reaction from putting the card in. If you hit the PROGRAM key with a card in you should get a flash of the BUSY light as it checks for User progs.
    There is no relationship between the card and the Lithium battery – you should only suspect the battery if you regularly get bad checksum messages on powerup.
    It is not necessary to send the unit back home to change the battery –  a dealer or technically competent person should be able to do this (if necessary – see above).
