Reply To: Having trouble with updatingto 5.5 using the Flash Card on H8000FW
Home Forums Products Rackmount Having trouble with updatingto 5.5 using the Flash Card on H8000FW Reply To: Having trouble with updatingto 5.5 using the Flash Card on H8000FW
#120957
Eric Zimmermann
Thanks for the response. Let me back up a bit, long story short, my situation is nearly identical to DroolMaster0's from what I can tell. When I put the Compact Flash Card into the H8000 to update from 5.0 to 5.5, with a properly formated card (I've experimented with several brand new cards and adapters) I consistently get stuck on the prompt of "OUPDATE, awaiting contact" with a "restart" and a "done" option. The unit doesn't freeze or anything, I just hit either restart or done so I can start working.
If I understand the directions for 5.5 properly you can only use the CF card to update to 5.5 is that correct?
Thanks
Eric
