Home Forums Products Rackmount Eleven rack and Eclipse tap tempo Reply To: Eleven rack and Eclipse tap tempo
#121050
thomasb
    Thanks, I've tried you're suggestions and similar but it still doesn't work.
    Tempo is set to ext. 1. Ext. 1 is set to damper (it comes up with base -1) though when I hit capture and step on the pedal it shows MIDI double, not damper anymore. The monitor show a bit over 50% but it doesn't move nor does the tempo change. Seems like the only solution is to make a split cable from a pedal and feed the direct pedal inputs (pedal inputs on 11R and Eclipse work perfectly for tap). Still I find it very strange that the Eclipse seems to receive midi data (the busy light flashes when I tap) but it won't be directed to tempo. Sad to hear that AVID is slow with fixes on such issues. Tap tempo is a crucial feature.
