Home Forums Products Rackmount New Tap Tempo Issue! Reply To: New Tap Tempo Issue!
#121386
    My guess is that if you pick different ext numbers, the problem will go away. Ext1-4 are often pre-programmed into the effects, so will be doing more than you think. Try ext5 and above.
