Reply To: H8000FW, Windows 7 64-bit, Pro Tools 9 (not HD)…how do you set up the Firewire?
Home Forums Products Rackmount H8000FW, Windows 7 64-bit, Pro Tools 9 (not HD)…how do you set up the Firewire? Reply To: H8000FW, Windows 7 64-bit, Pro Tools 9 (not HD)…how do you set up the Firewire?
#121489
ameyrairikar
In the Setup Menu , you should see an option for playback engine. Select Eventide as your playback engine.The stereo channels listed as analog you see are your outputs from Firewire interface. However, you might want to route the signal through the H8000 FW according to your requirements using Routing Utility.
Since you are using both the fire wire ports , You should be able to see all 16  channels in your I/O section in Protools.Hope this helps.
