Home Forums Products Rackmount Somebody found a sequencer for the 8000 Reply To: Somebody found a sequencer for the 8000
#121564
sean.e
    From the help file in VSig, here is the description of the Sequencer module:
    The sequencer module
    is used to create a repetitive sequence of "mod" signal output values. This is
    very useful in creating a pitch arpeggiator with a pitch shifter.
    The sequencer
    functions like a table lookup. A specified number of values are stored in
    memory, and depending on the value of the audio input signal, the corresponding
    value is sent to the output. To create a sequencer, a ramp waveform from an LFO
    drives the input of the sequencer, producing a consistent pattern of output
    values. (On the LFO, a ramp is a triangle with 100% duty cycle)
