Home › Forums › Products › Rackmount › Sorry ,I’ll explain more simply my MIDI problems with Eventide H8000fw › Reply To: Sorry ,I’ll explain more simply my MIDI problems with Eventide H8000fw
#121595
    Thanks. That's better. But, I cannot duplicate your problem.
    My guess is that the internal ram is corrupted, maybe as a result of not doing a CLEAR SETUP after an upgrade. Either way, a CLEAR SETUP will probably fix it, at the price of removing any of this sort of remote programming that you have done.
    Another approach would be to look at the knob controls that are misbehaving – I suspect is that if you press and hold SELECT, you will probably see that they already have remote connections assigned. Or, look for the flashing underline under the name.
