Home Forums Products Rackmount Eclipse foot pedal question Reply To: Eclipse foot pedal question
#121710
    Don't understand – by definition, if you hit a tip+ring button, it will activate both the tip and the ring circuits. If the Eclipse is set to recognize tip+ring, it will ignore a tip or a ring by itself.
    I assume you are using diodes or a 2 pole switch for the t+r. You should check out the switch functions with a continuity tester before connecting it to the Eclipse.
