Home › Forums › Products › Rackmount › h8000fw with nuendo 5 › Reply To: h8000fw with nuendo 5
March 23, 2011 at 5:46 pm
#121783
Hi Fabrizio
I think the menu for Cubase 5 and Nuendo 5 should be similar.So inside the Device – Device Setip – VST Audio System menu, you should be able to see ASIO Eventide Dice as an option for the I/O.
Once you do that, you can activate the firewire channels as audio buses using the device – vst connections menu. I recommend using the routing utility to get more comfort with regards to routing the audio the way you want.
Sincerely
Amey Rairikar
