Home Forums Products Rackmount Internal Memory Checksum Error Reply To: Internal Memory Checksum Error
#121818
jcshirke
    Well, I couldn't help myself. I just tried the battery wiggle trick. It didn't work. I took the battery out, dusted it off, and put it back in. But, no dice.
    However, the Utility/Setup/Fix/"Yes" (clear internal RAM) trick did work–or so it seems. I'm no longer getting the IMCE message on startup. But does that really mean that I took care of the underlying problem–as the manual warns?
    What's the next step? Wait and see if the error message returns? Forget about it (as the manual clearly warns against)? Send it to the fine folks at Eventide?
    Thanks,
    Jeff
