Home Forums Products Rackmount H8000 fw Remote control levels perfectly functionning with the V5.5 update Reply To: H8000 fw Remote control levels perfectly functionning with the V5.5 update
#121828
    E.M Pulinx:
    No bugs anymore  !
    Good !!
    E.M Pulinx:
    What is there to do in order to supress this EXT regular blinking ?
    The ext regular blinking is there to annoy our users. It is often very successful at this. Beyond this important function, its other role is to tell you if any routed digital inputs are unlocked. Since the machine does not always know whether or not you are using a connected input, the led flashes if any routed input is unlocked, regardless of whether you think it is important.
    To fix it you have to look at all the routed digital inputs and unroute those that are not actually needed. Often, things can be connected to, say, ADAT out, even if you are not using it.
