Reply To: “Repeat” function for TimeFactor map to an “External”?
Home Forums Products Rackmount “Repeat” function for TimeFactor map to an “External”? Reply To: “Repeat” function for TimeFactor map to an “External”?
#121855
Hi BMF
Setting the External to your remote source is the first step.
The second is to connect the parameter to that External. To do this, first find the parameter – REPEAT is one of the "hot keys" for a TF preset.
Then, follow the instructions under "Patching a Parameter to the Modulation Block’s “Modules”" UM p.40. While this refers to Modulation Block it also applies to Externals.
You have to read every page – we like to hide the good stuff !
Cheers !!
