Home Forums Products Rackmount H8000fw plugin style Reply To: H8000fw plugin style
#121997
Which DAW are you using? I know that Cubase 5 and later allows you to use any piece of hardware as a plugin, and I think I've heard of several others that do as well. You can always route audio through the H8000FW and record the results. That's not quite as flexible as a plugin, but can get the same results.
