Home › Forums › Products › Rackmount › wammy via sequence MIDI › Reply To: wammy via sequence MIDI
April 25, 2011 at 11:02 pm
#122012
To assign a parameter to be controlled by an External
you press and hold the soft key under the parameter. Then press the
<MODULATE> soft key. From here you can assign a variety of things
to control that paramter, including any of the Externals.
