Home Forums Products Rackmount Continuous Foot Pedal not working to control low pass filter Reply To: Continuous Foot Pedal not working to control low pass filter
#122027
    Hi Mr Zap
    Don't really understand you. It sounds like you are saying that your pedal will not control over the full range. This may be because you pedal itself is not covering the whole range – look at the "monitor" on the externals page to see if it is sweeping far enough. If not, you may want to try calibrating the pedal (UM p.92).. Or, you can try "scaling" the controller (UM p.104).
    But, note that when you remote control a knob as you describe, you cannot exceed the range of the knob, for fairly obvious reasons.
