Home Forums Products Rackmount Mixing with Eventide Eclipse Reply To: Mixing with Eventide Eclipse
#122034
    The Eclipse itself, when connected digitally, will have very little delay – probably less than 20 samples. The main issue is that almost everything done on a computer involves buffering which will introduce delays from (typically)  64 to 1024 samples.
    You should contact your computer hardware and software suppliers to see how much latency will be added with the outboard send.
