Home › Forums › Products › Rackmount › Orville V3.002 Software Update ~> E100 (Open Command Ack Error 100) › Reply To: Orville V3.002 Software Update ~> E100 (Open Command Ack Error 100)
May 12, 2011 at 7:21 pm
#122100
Thank you kindly for the reply nickrose.
I exhumed an old (ancient) PC and successfully applied the update.
One additional, potentially causal, detail I neglected to mention is that the PC I initially used (detailed in OP) does not have a serial port and I am utilizing a USB-to-Serial converter (TRENDnet U-S9). Are there known issues with this type of connectivity?
I am receiving the following error via VSig upon executing "Get Dbase":
"Get User Files" & "Get Setup" both work without issue.
