Home › Forums › Products › Rackmount › Ecilpse phasing › Reply To: Ecilpse phasing
May 16, 2011 at 8:25 pm
#122118
Hi and thanks for the quick answer.
Yes i get phasing because the Eclipse is in a mixer, in a effect send.
I use the unit live in a guitar rig where i mike the cab to a mike pre-amp that feeds my rack. The rack has a line mixer where the Eclipse is in an effect send.
The unit set-up so that when i change to a preset either blocks can be on or off . Block A and Block B on/off are assigned to 2 controllers from a midi controller.
I have tried just taking the out of the Eclipse and I hear some dry signal blleding thru when both blocks are off. The only time i do not get some blled is if i put the whole unit in bypass mode.
I just updated the unit sytem to 4 but previously i had the same set-up and when bypassing both blocks i did not have any dry signal coming out of the unit.
The unit is set-up to 100% wet and both blocks are set-up 100%wet.
Is there a new menu in version 4 where the blocks bypass is set-up to have or not have the dry?
Hope this helps.
Regards.
Pierre Gauthier
Show More...Show Less...
