Home Forums Products Rackmount Routing is in Demo mode Reply To: Routing is in Demo mode
#122183
    I assume that you refer to the Routing Utility.
    Check that Comms Config is set up properly and your cables are good.  Make sure that MIDI Sysex ID is set to 1, and that baud rates agree if using serial. You should see the BUSY light near the card slot flash every few seconds.
    If you are using FireWire MIDI, make sure you have the latest drivers.
