Home Forums Products Rackmount connecting to a multi-port midi interface Reply To: connecting to a multi-port midi interface
#122190
    Check to see if the BUSY light on the Eclipse flashes when you think you are sending it MIDI – if it does, check channels etc, or use "MIDI capture" to identify what is being sent. If it does not, the MIDI is being lost before it gets to the Eclipse, and you'll have to speak to Mr.Motu.
