Home Forums Products Rackmount Internal RAM is New – Error Reply To: Internal RAM is New – Error
#122299
    Sounds like your battery is flat. Replacing it should solve the problem.
    But, the battery should last more than a year (typically 5-10). I would suggest that you try another battery, in case the last one was weak. If this also runs down quickly, you should contact support@eventide.com
