Home Forums Products Rackmount Help with 2 x 2290s patch Reply To: Help with 2 x 2290s patch
#122519
jcshirke:
Do those ins and outs correspond to whatever DSP you're running this
algo on?
They do. Sounds like you need to study the routing a bit (if you have not already, try the Routing Utility from H8000 support section). This will also give some clues about mixing outputs to mono.
