Home Forums Products Rackmount Need help setting my midi pedal up with the virtual rack presets Reply To: Need help setting my midi pedal up with the virtual rack presets
#122549
eraserhead
    Hello
     I have read loading a program remotely and that more about program change with a Midi controller. I will try to explain the problem again.
     in bank 66 virtual racks preset 20 monster rack there is a total of 4 effect which is you can turn/on via MIDI controller. Right now on my GCP i have button 4 to turn on/off the shifter which i got it to work the only problem is that i have to hit that button 2 times vs 1 time to turn it off and i have to hit it another 2 times to turn it off. I would like it to act just like a stomp box the way it was made.
    Here the steps i used
    1. Reset the ground control and then name it eventide.
    2. i set the GCP to 8 instant access and 4 preset mode (1-8 turn effect on/off and the last row which is 1-4 changes the preset)
    3. set the cc device ID or CC to 1 so they talk to each other.
    4. loaded the monster rack preset.
    5. Hit the control tab 2 times and i'm on the shift sw setup it then says mode assign 4  and on the right i highlight capture MIDI
    6. As capture MIDI is highlight i hit select and hit the number 4 midi button on my GCP.
    7. I then go back to the monster rack main screen showing the effects and the on/off right next to it.
    8. I hit the number 4  button once and nothing i hit it one more time it goes to off. To turn it back on i have to hit the button more 2 times.
    I know there's a way for it to work hitting just the button one time because when i first got the unit somehow i got a few of the effect to do that but i also had a few buttons that were messed up so i reset the system.
    Thanks again
