Home Forums Products Rackmount H8000 , each DSP in separate FX analog loop stereo Reply To: H8000 , each DSP in separate FX analog loop stereo
#122556
    As you observe, the H8000 was mainly designed for digital use, and thus only has two Analog lines, largely intended for monitoring purposes.
    To answer your other questions, try downloading the Routing utility (PC or Mac) from the appropriate support page – this will show you the connection options.
