Home Forums Products Rackmount DSP-4000 Checksum Errors, please help. Reply To: DSP-4000 Checksum Errors, please help.
#122707
    Check sum errors may come from the battery-backed ram. If your software allows it, try setup/service/fix, which will cure a bad checksum. If it reappears after powerup it is almost certainly the battery.
    If you need a battery, see http://eventidestore.com/insrme1.html – note that they are not cheap. They usually last about 10 years, so given the age of any DSP4000, it might well be the cause.
