Home Forums Products Rackmount Eclipse in effects loop? Reply To: Eclipse in effects loop?
#122710
Thanks Nick :o)
The Eclipse is 100% wet it is the loop that only passes 50% signal through the eclipse and 50% straight out to power amp. Thought it was the delay in the Eclipse causing this, and guess this may also be why it works fine on an old H3000 (older ADA converters).
