Home Forums Products Rackmount TimeFactor presets for H8000 only processing Input 1 (mono input) Reply To: TimeFactor presets for H8000 only processing Input 1 (mono input)
#122723
h8xlolo
Thanks for your quick answer.
imho it would make sense to provide summed in for all presets, as it is the case with many other H8x presets.
example: In my configuration I use 2 signal path to two guitar heads (using A/B/Y box) and  use one H8x dsp to process the 2 channels as a stereo signal on top of dry in parallel (processed signal goes in a pair of speakers, kind of wet/(dry+dry)/wet configuration ). Without summed in presets, when I play with head A path I have effect, with head B I have no effect, with A+B I have effect but only based on A input. I know I could use routing to do that but it would not be very flexible.
Do you think summed in could be consider for 'mono' TF presets in a future release ? Let's say it is on my wish list 😉
Thanks,
Laurent.
