Home Forums Products Rackmount REMOTE CONTROL PARAMETERS / MIDI GROUP Reply To: REMOTE CONTROL PARAMETERS / MIDI GROUP
#122873
    Audiotistic:
    1) if i want to use the EVE/NET as my external controller, the midi in out plugs on it are not fitting tightly….can i just connect midi in out on back of  H8000?
    Yes.
    Audiotistic:
    2) In logic do i need to create an external midi track and record enable it then press record to capture automation?
    Sorry – this is a question for Mr.Logic – beyond our product knowledge.
    Audiotistic:
    3) Let say as an example i wanted to assign the reverb DECAY parameter to be modulated via the large, main spin knob on the EVE NET
    The wheel on the Eve/Net works the same way as the wheel on the H8000 front panel – it adjusts the currently selected parameter.
    To use MIDI instead, look at "Automatically" Selecting a MIDI External Controller" on p.103 of the UM. This should tell you how do do it, but if there is anything specifically that you don't understand, please ask.
