Reply To: H8000FW Firewire Weirdness
Home Forums Products Rackmount H8000FW Firewire Weirdness Reply To: H8000FW Firewire Weirdness
#122897
Not sure what you mean by the win signal..
Also, you don't say what you are trying to lock the unit to – we don't recommend that you use firewire as the sync source – there are usually better options.
Also (sorry to be so negative) you can't upgrade the unit over firewire – you usually have to use a CF card. This is mainly for reasons of reliability – a failed upgrade can brick the unit.
