Home › Forums › Products › Rackmount › Ramp up value? › Reply To: Ramp up value?
March 27, 2012 at 4:28 pm
#123260
I sorta did this with a dirty trick.
I used the ADSR triggering with ch1 input volume. Then I patched the ext5 to the SEND parameter, starting from 50% to 100% with instant change. The ADSR is set to trigger with a send volume which is normally not attainable when it is at 50% – so when the CC sets the send volume to 100%, the adsr triggers and stay there while i'm playing, altering the m_level of the effect nicely. Of course I lowered the wet volume accordingly and could do this just because i'm using the eclipse in a dry/wet rig and only the wet signal is output by it.
Thanks anyway
