Home › Forums › Products › Rackmount › I need help with a basic setup › Reply To: I need help with a basic setup
April 19, 2012 at 3:58 pm
#123336
To assign Bypass to be controlled by a MIDI command, press the Setup button three times and then press the EXTERNAL soft key.
Now press the Setup button five times and you will see a BYPASS softkey. Press this and you can choose an External to activate Bypass.
Now go to that External and assign it to whatever MIDI command you want!
Alan
