Home › Forums › Products › Rackmount › Last results with Eventide H8000fw big verbs › Reply To: Last results with Eventide H8000fw big verbs
Hi Nick !
-all levels in/out let on 0dB
-factory analog A // B
-disp A thru
-disp B : running the verbs on dspB ,as you suggested:
1)black hole : set on his usual level :28% :only the dry sound is coming, no change if the levels are set higher
2) glorious chorus canyon : set on hisusual level :25% :only the dry sound is coming, no change if the levels are set higher
3)majestic plate :set on his usual level :42% : absolutely normal,we have the normal reverb
Now, the inverse situation:
-disp B thru
-disp A :
all the modulation effects put in (ring taps,galaxy borders,beyond the stars,etc) , are coming out totally normally !
BANGS :
2 big verbs :black hole and glorious canyon in our studio ,H8000 only , placed in the loops of different Rivera and Fender amps
-on a total running time of 22H45m, we had 5 terrific big bangs ,otherwise all was correct.
Our studio is set on a automatic voltage regulator,and protected by all means.
-One month ago,on a total running time of 9H45m of the verb "majestic plate" ,we had 0 bangs
hpe it helps !
cheers
EMP
