Home › Forums › Products › Rackmount › vibrato + distortion › Reply To: vibrato + distortion
December 28, 2012 at 8:56 pm
#124135
You should look through the Presets Manual. To run two effects at the same time they both need to be labeled "xfade."
There are a number of "xfade" distortion effects and a number of "xfade" vibrato effects, so if you used one of each, you should be moving in the right direction. But, you will want to tune them by ear for the right sound.
