Home › Forums › Products › Rackmount › CC Over MIDI in Eclipse › Reply To: CC Over MIDI in Eclipse
March 14, 2013 at 3:51 pm
#124371
You can either choose the MIDI CC yourself, or as you say, let the MIDI capture do the work for you.
The MIDI base + 2 is not usually a requirement, more of a convenience, where you can set a base channel and relate everything else to it. In almost all cases, you can set it to base and keep it simple.
