Home Forums Products Rackmount Bypass (Mute-All) not working when AES/EBU i/o are used Reply To: Bypass (Mute-All) not working when AES/EBU i/o are used
#124561
    Hi Max
    You are right – the AES appears to use DSP bypass (giving you the dry signal when bypassed) even if the bypass mode is set to mute.
    If you need it to be truly muted, you could use MSTR OUT gain as as a mute – this will affect both the analog and digital.
