Home Forums Products Rackmount ADAT in, AES/EBU out Reply To: ADAT in, AES/EBU out
#124579
    It sounds like you need to decide what piece of equipment is to be clock master. Getting this wrong will give the crackles you mention. You need to have a single clock master, with everything else synched to it. For example, you could decide that your Audient is to be the clock master, and then you would set your Eclipse clock to ADAT, and then connect by AES to the Roland.
