Home Forums Products Rackmount EVE/NET Level LEDs Not showing Reply To: EVE/NET Level LEDs Not showing
#124590
sebastiank
    Thanks for the reply.
    Version number is: 5.5
    The LEDs definitely used to work, I have a video where they show the levels right when i was set up before, and when the EVE starts up they all show fine. As soon as DSP B loads the LEDs all turn off
    In terms of whats changed: I just reconnected everything after moving house, the one thing that i did do was a SERVICE > CLEAR SETUP as i was finding it difficult to get the routing right and wanted to start from a clean setup.
    I dont know if this helps but the front of the harmonizer level LEDs are in columns 5 and 6 of the 8 wide LED indicators there. Does the EVE/NET only show channels 1-4? If so how do I change that.
