Home › Forums › Products › Rackmount › Eclipse error message on startup: “BADALG2 HEAD CG:1.8 ALG: 0.0 PRESS ANY KEY TO CONTINUE” › Reply To: Eclipse error message on startup: “BADALG2 HEAD CG:1.8 ALG: 0.0 PRESS ANY KEY TO CONTINUE”
#124677
    First, double check that your unit really is V4 ( see "Finding Out The Current Software Version" UM p.57).  This sounds like an issue that was present in an r=earlier version.
    If it is V4, I would suggest  that you try the procedures described under "Fixing Strange Behavior, Freezes, Etc." on UM page 53.
    If it proves to be a hardware problem and your unit is less that a year old it should be covered under warranty.
