Home Forums Products Rackmount Adat Routing at 96Khz Reply To: Adat Routing at 96Khz
#124883
MFPhouse
    hi creativeblue,
    we talking about Operating Sys 5.5 . Don´t know the new 5.6 .
    System Routing Utility didn´t work with this Setup ! So you have to do it manualy in the Eventide Sys Routing Setup Menu.
    ADAT 1-2 using DSP A and ADAT 5-6 using DSP B . Serial -( A-B ) – worked after reboot .s.u.
    The Main Out of the ADAT Output Window has to be configured as follow.
    Main Out 1 – Out 1
    Main Out 2 – Out 2
    Main Out 5 – Out 3
    Main Out 6 – Out 4
    On the Right side as follow.
    Main Out 1 – Out 5
    Main Out 2 – Out 6
    Main Out 5 – Out 7
    Main Out 6 – Out 8
    Versi Versa on Input if needed ( depends in SMUX Modus – the Contrahand )
    Here it´s works with the RME 800 ( old version ) .I think it´s like your RME Raydat.
    There is a BUG ! If you often Change between 44,1/48 and 88/96 Projekts the H8000 crashed.
    So, if you have to , just reboot the Eventide before changing / Loading your other Khz Projekt in your DAW.
    PS: I think it has someting to do with loaded Presets wich using the Timer or many Audio to Controll Modules wich use the ( half ) of Sampling Freq. for controll realtime Data. ? anyway
    It´s works here fine.
