Home Forums Products Rackmount Newbie questions on Aux – Orville hookup Reply To: Newbie questions on Aux – Orville hookup
#125361
    Hi Gareth
    gareth33:
    I have yet to fully understand the routing within Orville and how to input a signal correctly.
    I would recommend the Routing Utility, available free from the Web Site. This is really for the more recent machines, but if you set it up for H8000A and ignore channels 5-8 where dispolayed, you'll be close enough. I would STRONGLY advise close study of the factory routings as well.
    gareth33:
    let's say I have a mono synth
    How to route this depends a bit on the preset and what you are trying to do, but if you route it  to all 4 DSP inputs, it should work with most things.
    You should not need Y cables, as you can do most things inside Orville. A stereo return to your mixer would be reasonable. Make sure you use a parallel routing if you are feeding A and B from separate places to mix their outputs.
