Home › Forums › Products › Rackmount › Common problems with Eventide H8000fw › Reply To: Common problems with Eventide H8000fw
#126780
    A new one will be covered by the warranty.
    For a used one, check that it works and nothing is loose inside. Make sure the mounting ears are not bent and that all the inputs and outputs are functional. Try and get a warranty from the seller (good luck).
