Home › Forums › Products › Rackmount › Questions on Orville and H8000FW › Reply To: Questions on Orville and H8000FW
#126806
Ok.. Regarding:
1) The Midi – Add Midi controller : this is for testing midi control in a patch that is set up for midicontrol only, and not for assigning a midicontoroller?
2) Using the EXTCONTROL module, it's easiest to allways set Spec1 field to 0, then load program to the Harmonizer and then set up for the right midicontroller on the H8000FW screens?
