Reply To: Tempo via MIDI Clock?
Home Forums Products Rackmount Tempo via MIDI Clock? Reply To: Tempo via MIDI Clock?
#127221
Fernando Ulibarri
I want to add to the list here…
Running Pro Tools HD 11.3 into a V4 Eclipse. Using OS 10.9.5 and a Roland UM-880 Midi Interface.
Midi Clock works somewhat. If I switch my session tempo to anything around 100 and do a tempo change to something close to it, it works (takes like 2 measures to catch up).
If however, I set a tempo to 40, and a tempo change to 60, the Eclipse ignores the change. I'm monitoring this on the setup page.
If I use the big knob to change the tempo from what the Eclipse has to anything else, then it will snap to the session tempo. Seems to me like the slower tempos are buggy. Could this be my MIDI interface?
Tap Source is set to MIDI Clock, The Eclipse is on AMS set to receive MIDI clock, and PT is sending clock to the Eclipse as well. Am I missing something?
