Home Forums Products Rackmount H8000/EveNet issues Reply To: H8000/EveNet issues
#127337
    Don't quite understand what you are saying, but you do maybe have a connection issue. Things to try:
    1) Make sure everything is terminated properly as described in the UM. My guess is that it is not, and that this is the problem.
    2) If you are sure that the above is not the case, try different cables.
    3) If all else fails, go back to your dealer.
