Reply To: H8000/EveNet issues
Home Forums Products Rackmount H8000/EveNet issues Reply To: H8000/EveNet issues
#127344
homer
Not sure what is unclear, Nick. I will try again: When I dial in a preset via the EveNet it will sometimes jump to a specific patch (always the same one) and it does this autonomously w/o any further interaction from my side. Like I said will also occur when you dial in another patch but before the UI will be fully built up in the display of the EveNet. I've changed the ethernet cable but it did not help. In a sense my question was also if the EveNet should be functional with other length parameter values. Just for fun I tried to change from 300 to a lower or higher value but that always leaves the EveNet unresponsive.
Anyway, I will check the termination….and no, unfortunatley I don't have a dealer as it was bought used.
