Home Forums Products Rackmount Comms Tip for H8000FW Reply To: Comms Tip for H8000FW
#127467
Hi, sorry yes was a bit vague.  I'm using a Firewire connection directly from PC to H8000FW.
I thought you could use any MIDI interface and select that as well, but my testing doesn't show this works. I've tested my Saffire Pro 40 as an interface, and the Routing app just goes into Demo mode after a few seconds.
Using Dice works even with MIDI and Serial turned off on the H8000FW global configuration, so they must be doing something a bit tricky. Maybe it's just me..
